Normal Topic How to specifiy ToolTip width/height ? (Read 1362 times)
jlj30
Nov 8th, 2012 at 9:29pm
Is there any way to specify the width and height of the ToolTip for  a ShapeNode?
I am able to display the ToolTip but it's very wide and narrow.
Using Java Applet mode.
Thanks in advance.
Jim
Re: How to specifiy ToolTip width/height ?
Reply #1 - Nov 9th, 2012 at 7:31am
Java can display HTML tooltips, so you could use a div element to specify width:
node.ToolTip = "<html><div width='80'>long tooltip text goes in this div</div></html>";
