Hot Topic (More than 10 Replies) why the shapes on loaded can't be shown as i designed (Read 4816 times)
webdev
Nov 15th, 2012 at 7:12am
i designed shapes on shapelist
but when i load my diagram,
the icons aren't show as i wish
they all shown in the same style
border-radius rectangles....
could you help me
saad
Re: why the shapes on loaded can't be shown as i designed
Reply #1 - Nov 15th, 2012 at 3:50pm
i think you have to delete the extra icons in shape designer and keep only the ones you want shown.
webdev
Reply #2 - Nov 16th, 2012 at 5:15am
sorry,i've designed my own icons,and set the shapelistlibrary for shapelist widget. i  drag icons to the diagram to draw a flowchart ,submitted and saved it. but when i reloaded the flowchart , the icons aren't show as i
designed in the shapelist ......did i forget to set any properties for the diagram?
Reply #3 - Nov 16th, 2012 at 7:16am
You should load your shape library before loading the saved diagram. Otherwise the missing shapes are replaced with default rounded rectangles.
webdev
Reply #4 - Nov 16th, 2012 at 11:28am
could you tell me how to load shape library  to  the diagram.i've set the shapelistbox correctly, and when i drag icons to the diagram ,the icons show correctly. when i saved it and reloaded them, they are shown default style as you told.
Reply #5 - Nov 16th, 2012 at 11:45am
In Java mode, setting ShapeLibraryLocation on the listbox will load the shapes only on the client side once the applet is loaded. To load the shapes on the server before the diagram file, call ShapeLibrary.LoadFromXml, or set ShapeLibraryLocation on the DiagramView as well.
webdev
Reply #6 - Nov 16th, 2012 at 2:44pm
thanks to your help, my problem has almost been solved.
but i settled about 3 pages and designed different shapelist style for them.  i set shapeLibraryLocation for the diagramView and shape list box for them,but when i changed pages,only one of them worked, the default rectangles are shown on the 2 pages...didn't i forget to settle any properties?
Reply #7 - Nov 16th, 2012 at 3:09pm
Are these pages in different folders? If they are, try specifying full path when calling ShapeLibrary.Load.
webdev
Reply #8 - Nov 17th, 2012 at 4:37am
they are in the same folders.
and the problem always exists....
only one of my shapelists could work when i
changed pages
webdev
Reply #9 - Nov 17th, 2012 at 5:47am
i set 3  sub pages and a main page.
the main page has 3 <a> and a <iframe>
i used <a href="subpages" target="ifm"> to change pages.    i set 3 different shapelibraries and used them  for the 3 sub pages .  the diagramviews and shapelistbox are all set the property --shapelibrarylocation and used relative path.
the problem is :when i  launch the server and wanted to add shapes into the diagramview, only the first page will show correctly. and when i changed pages to another two pages ,the shapes are shown into round rectangles (the shapes are shown correctly in the shapelist box in any case)....
that's my problems.
my project based on the .NET platform and use C#
Cry
Reply #10 - Nov 17th, 2012 at 8:12am
The shapes will be shown as rounded rectangles if they are not defined at the time when you call LoadFromFile. If you are loading different shape libraries for each page, then check if the file you load into DiagramView really contains shapes from the current shape library. As a quick test, try loading all three shape libraries by calling ShapeLibrary.Load before Diagram.Load.
