Normal Topic Grouping by Contacts and drag and drop one item (Read 2735 times)
Pascal P
Nov 20th, 2012 at 10:14am
We have the calendar-control with the view Timetable and we used the GroupType GroupByContacts.
With this setting I cannot drag and drop one item from one contact to another contact. Is there any setting or way to do that?
thanks a lot for your help.
Re: Grouping by Contacts and drag and drop one item
Reply #1 - Nov 20th, 2012 at 10:34am
Try setting Calendar.ItemChangeResourceKey (ItemChangeReferenceKey in older versions) to Keys.None.
Pascal P
Reply #2 - Nov 20th, 2012 at 11:46am
Great, this works.
Thanks.
Note: We have not the newest version of planner.net. It´s version 5.0a, also the setting is ItemChangeReferenceKey.
But the change of the property from ItemChangeReferenceKey Alt to None doesn´t work when I made the change in the designer. It look´s like the change in the designer makes nothing.
I made the change in code:
calendar.ItemChangeReferenceKey = Keys.None;
and it works..
