Normal Topic Selection Rectangle - only on diagram background, not on nodes? (Read 2283 times)
ulthien
Dec 6th, 2012 at 1:18pm
Currently (after longer pause on this part of code) i have disabled
ModifierKeyActions.Control = ModifierKeyAction.Select;
Selection Rectangle, as i reused ctrl- drag to implement node cloning on drop.
but...
how to have a Selection Rectangle that works only when drawn from diagram background (without and modification key), and not starting on nodes?
namely, i have
ModificationStart = ModificationStart.AutoHandles;
that allows node moving on drag (without prior selection), and here i added ctrl- drag to clone on insert. So starting of select rectangle with ctrl- is no more feasible.
Re: Selection Rectangle - only on diagram background, not on nodes?
Reply #1 - Dec 6th, 2012 at 2:25pm
Create a custom behavior class that returns new InteractionState(Diagram.Selection, -1, Action.Create) from the StartDraw override, when there are no nodes under the mouse pointer.
ulthien
Reply #2 - Dec 6th, 2012 at 3:04pm
Thank you, will have a look at it Smiley
cheers
