Normal Topic Border after loading from file (Read 3795 times)
Robert Simon
Feb 3rd, 2013 at 4:13pm
i have designed and saved a diagram (SL v11.1), it looks fine.
but when i load it from the saved xml file there is a border around each nodes
can i disable it somehow?
thanks,
Re: Border after loading from file
Reply #1 - Feb 4th, 2013 at 6:54am
Have you by chance derived from ShapeNode in order to override its control template? In such case, you will have to call the RegisterItemClass method when initializing your application to associate an XML string id with the custom node class.
Robert Simon
Reply #2 - Feb 4th, 2013 at 9:37pm
I do this on loaded. shall i repeat it later on?
           private void UserControl_Loaded(object sender, RoutedEventArgs e)
Diagram.RegisterItemClass(typeof(MyNode), "my:MyNode", 1);
                 diagram.CustomBehavior = new MyBehavior(diagram);
                 diagram.UndoEnabled = true;
            overview.Document = diagram;
            AnnealLayout layout = new AnnealLayout();
            layout.Arrange(diagram);
            diagram.ZoomFactor = 100;
            slider1.ValueChanged += slider1_ValueChanged;
Reply #3 - Feb 5th, 2013 at 9:12am
If the visibility of that border is controlled by a custom property of yours, you should save and load its value from within the SaveToXml and LoadFromXml overrides. What does the MyNode's Xaml template look like?
