Normal Topic how to limit the number of link's segments (Read 2016 times)
hans
Feb 8th, 2013 at 5:01pm
The programmer's Guide says:
The number of link's segments is specified by the setControlPoints method. Should I just remove some of the getControlPoints()? But I assume that after rerouting
the link there will be more controlPoints again ?
Is there an overall-setting for the number of segments?
Re: how to limit the number of link's segments
Reply #1 - Feb 12th, 2013 at 7:49am
I suppose you could disable automatic routing, and call the route method of links in response to events such as nodeCreated/Modified and linkCreated. Then if you decide there are too many points, remove some of them, but you will probably get the links to cross some nodes in that case.
