Normal Topic Hard to hit the link end - LinkHitDistance seems not to work (Read 1363 times)
K Karkov
Mar 1st, 2013 at 8:00am
I have a setup with some TableNodes I connect with DiagramLinks. But after I updated to Winforms Pack 2012.R4, it's pretty hard to catch an existing link end for moving. I have to hit the exact anchor point center to get it. I have tried increasing LinkHitDistance but I see no difference.
Re: Hard to hit the link end - LinkHitDistance seems not to work
Reply #1 - Mar 1st, 2013 at 9:08am
I could not reproduce this, could you attach a diagram xml file here or post your diagram and items initialization code?
K Karkov
Reply #2 - Mar 8th, 2013 at 7:13am
Thank you very much for quick and competent help Wink
As you found out I had changed the MeasureUnit in my Diagram from Millimeter to Pixels. But doing so did not change AdjustmentHandlesSize. After increasing AdjustmentHandlesSize from 2 to 6 as you suggested, my problem was gone!
I just want to warn others to change to Pixels, as a lot of other problems come up doing so. Printing is completely f….. up.
Thanks again.
