Normal Topic Adding an Undo command without executing it (Read 1081 times)
j poz
Mar 11th, 2013 at 4:35pm
Is it possible to add an undo command to the UndoManager without executing it?
Something like UndoManager.Commands.Add(...)... ?
Re: Adding an Undo command without executing it
Reply #1 - Mar 11th, 2013 at 5:19pm
I can't find a public method to do that. If it's a custom command, you could implement Execute(bool) as empty method, and override only Redo to execute the action (by default Redo calls Execute). If you need this for standard commands, at this time you could wrap them inside some kind of NoopExecCommand that does not call the inner Execute but calls Undo and Redo.
