Normal Topic Inserting an Image into a ShapeNode (Read 1794 times)
jlj30
Apr 8th, 2013 at 12:28pm
I have several images (all the same size), that I would like to render within a simple rectangle ShapeNode.
It's probably a syntax issue, but here's my code.
All that I get is the rectangle; no image.
I've also tried just "Images/myShapeImages/User_Task.png" as the URL.
Suggestions?
Jim
ShapeNode taskType = factory.CreateShapeNode(0, 0, 5, 5, Shapes.Rectangle);
        taskType.ImageUrl = "http://vs2010prodevjim/NavviaNewDev/Images/myShapeImages/User_Task.png";
        taskType.Tag = "taskType";
        taskType.IgnoreLayout = true;
        //taskType.Transparent = true;
        taskType.Move(node.Bounds.Left + 1, node.Bounds.Top + 1);
        taskType.AttachTo(node, AttachToNode.TopLeft);
Re: Inserting an Image into a ShapeNode
Reply #1 - Apr 8th, 2013 at 1:54pm
You will have to set the Image property, e.g. assign to it the result of Image.FromFile(). ImageUrl was added for Canvas mode, and we haven't implemented it yet for other modes.
jlj30
Reply #2 - Apr 8th, 2013 at 2:12pm
Just what I needed Smiley
Jim
