Normal Topic beta version of diagram viewer library for Android (Read 6129 times)
Apr 16th, 2013 at 11:25am
We are starting beta tests of a diagram viewer control for Android. The library contains a View-derived DiagramView class that can be used to load and display XML files created by MindFusion's flow diagramming controls. Currently it can load and render ShapeNode, ContainerNode, TableNode, TreeViewNode and DiagramLink objects. Styles and themes introduced with Flowchart.NET V6 and WpfDiagram V3 can be loaded and displayed too, but visual effects are not supported at this time.
The library also includes all model classes and properties from MindFusion’s Java diagramming library documented at http://www.mindfusion.eu/onlinehelp/jdiagram/ , which provides your Android applications with access to the loaded links and nodes and their data properties, along with methods for simple hit testing from touch events.
If anyone is interested in trying the beta version, please download this archive, containing a Jar file that should be placed in the Android project’s libs folder in Eclipse:
https://www.mindfusion.eu/DiagAndroid.zip
A short tutorial showing how to add the library to an Android application and load a diagram file is available here:
http://mindfusion.eu/Forum/YaBB.pl?num=1366115421
« Last Edit: Apr 16th, 2013 at 12:34pm by Forum Admin »
