Normal Topic Text Wrap in TableNode (Read 2687 times)
Puneet Jain
Apr 22nd, 2013 at 9:51pm
I am unable to set the text wrap property on the tablecell. I am using the following code :
function onNodeCreated(sender, args)
var scriptHelper = <%= diagramView.AppletElement %>.getScriptHelper();
var node = args.getNode();
if(node.getShape().getId() == "TableCell")
var t = sender.getFactory().createTableNode(node.getBounds());
t.setCaption("");
t.setConnectionStyle(3);
t.redimTable(1, 4);
t.getCell(0, 0).setRowSpan(4);
t.setOffsetHeaderRows(true);
t.getRows().get(0).setHeight(t.getBounds().getHeight() - t.getCaptionHeight());
t.getRows().get(0).setHeader(false);
t.getCell(0, 0).setText("");
t.getCell(0, 0).getTextFormat().setWrapAtCharacter(true);
t.getCell(0, 0).getTextFormat().setNoWrap(false);
sender.getNodes().remove(node);
Please see the attachment. I am trying to add the following piece of text "Lorem Ipsum is simply dummy text of the printing and typesetting industry"
Please suggest.
Re: Text Wrap in TableNode
Reply #1 - Apr 23rd, 2013 at 6:41am
This Topic was moved here from Windows Forms [move by] Forum Admin.
Reply #2 - Apr 23rd, 2013 at 6:57am
At this time text will wrap inside table cells only if the EnableStyledText property is set:
t.setEnableStyledText(true);
