Normal Topic LinkDeletingScript is not getting executed (Read 1544 times)
Kiran B
Apr 24th, 2013 at 9:40am
When i problematically remove links from the diagram using the below method LinkDeletingScript is not getting executed. I need this event to cancel the delete in some scenarios. How can i achieve this?
function removeSelection() {
        var diagram = $find("diagramView1");
        var selectedItems = diagram.getSelection(); //returns both nodes and links
        if (selectedItems) {
            for (var i = selectedItems.items.length - 1; i >= 0; i--) {
                if (selectedItems.items[i]) {
                    diagram.removeItem(selectedItems.items[i]);
Kiran B
Re: LinkDeletingScript is not getting executed
Reply #1 - Apr 24th, 2013 at 11:04am
LinkDeleting is a validation event raised only when user presses Del for selected links to let you cancel the operation. If calling removeItem yourself, items are deleted unconditionally. To filter out some of them, add your condition to the if statement you already have.
If you are trying to delete nodes but keep their links, you will have to first change the link's Origin or Destination, e.g. set it to diagram.getDummyNode() result to make it an unconnected link.
