Normal Topic Vertically align boxes in the same layer? (Read 3424 times)
BF
Jun 7th, 2013 at 1:47pm
Id like to get all the boxes in the same layer vertically aligned to the top of the highest box in that layer (Using the Layered layout)
For example:
Is the FlowChart.LayoutStyle property the correct setting for this? Changing it does nothing as only lsVerticalCentered is supported according to the documentation.
Re: Vertically align boxes in the same layer?
Reply #1 - Jun 7th, 2013 at 4:50pm
That property is for container boxes. Nodes in a layer are always aligned by their center points at this time. You could find the topmost node in a layer and align the remaining boxes to it like this:
fcx.ArrangeDiagram ll
Dim topY(200) As Integer
Dim b As box
For Each b In fcx.boxes
    Dim i As Integer
    i = ((b.top + b.bottom) / 2 - fcx.DocTop) \ ll.LayerDistance
    b.Tag = i
    If topY(i) = 0 Then
        topY(i) = b.top
    Else
        If topY(i) > b.top Then topY(i) = b.top
    End If
Next
    b.MoveTo b.left, topY(b.Tag)
Next
BF
Reply #2 - Jun 10th, 2013 at 9:16am
Ok thanks for clarifying.
