Normal Topic Panning the diagram vs. creating a new node (Read 4449 times)
Rennie
Oct 27th, 2013 at 1:31am
I'm just starting to test the beta version of this module. Looks good.
Maybe I'm missing something obvious, but how do you pan a diagram that is larger than the display? The usual pan or swipe gesture with the finger results in a new node being created.
Re: Panning the diagram vs. creating a new node
Reply #1 - Oct 27th, 2013 at 7:01am
With two fingers, or set DiagramView.Behavior = Pan to enable single-finger panning.
Rennie
Reply #2 - Oct 29th, 2013 at 2:53am
Thanks.
Edit: Um, that should actually be
            DiagramView.setBehavior(Behavior.Pan);
right?
« Last Edit: Oct 30th, 2013 at 1:16am by Rennie »
Rennie
Reply #3 - Nov 6th, 2013 at 2:16pm
My simple little app based on the beta version of your Android product is almost done. As I said before, I think it is great that MindFusion has created a diagramming product that is multi-platform in a very compatible way.
But I have one comment about this Behavior=Pan thing. I don't think it should be a "behavior", because that means that you can't specify one of the other behaviors. For example, I'd like to specify Behavior=SelectOnly, and for another app I might want to use one of the other behaviors.
So I think the one-finger panning should be a separate option, and not considered a behavior.
Reply #4 - Nov 7th, 2013 at 9:43am
We can't see how to implement it as a simple bit-wise combination, there will be too many ambiguities. If you want to combine another type of behavior with single finger panning, you could derive from that behavior class (LinkShapesBehavior let's say), and start panning when you find it appropriate (e.g. there are no nodes at touch location). All the PanBehavior class does is the following, it shouldn't be hard to integrate into a custom class:
protected void pointerDown(Point pointerPosition, MotionEvent e)
	panPoint = new PointF(getDiagramView().getDocScrollX(), getDiagramView().getDocScrollY());
	ptStartDragDev = pointerPosition;
protected void pointerMove(Point pointerPosition, MotionEvent e)
	Rect visibleRect = getDiagramView().getVisibleRect();
	RectF rcPage = getDiagramView().canvasToDoc(visibleRect);
	float sx = panPoint.x - getDiagramView().componentToDocLength(pointerPosition.x - ptStartDragDev.x);
	float sy = panPoint.y - getDiagramView().componentToDocLength(pointerPosition.y - ptStartDragDev.y);
    getDiagramView().scrollStayInDoc(sx, sy, rcPage);
private PointF panPoint;
private Point ptStartDragDev;
Placing index and middle fingers close together and panning with both shouldn't be that hard for your users anyways.
