Normal Topic Using ShapeLibrary.LoadFrom with the DiagramApplet (Read 2717 times)
JR
Nov 28th, 2013 at 11:22am
We have found a problem with the use of the ShapeLibrary.LoadFrom method.
I am working with the version 3.4
We have a servlet which creates a graph. This graph has 2 shapes not given with JDiagram so we load these shapes with the ShapeLibrary.LoadFrom method in the servlet.
We generates a string with the savetoString method.
The DiagramApplet loads this string in the applet parameter DiagramData.
My new shapes are not displayed (a rectangle replaces it).
Interesting thing, I have defined anchor points for these 2 shapes and they are good in the display of the links.
If I don't display my graph in a applet, it works.
Is it normal ?
Juan
Re: Using ShapeLibrary.LoadFrom with the DiagramApplet
Reply #1 - Nov 28th, 2013 at 11:39am
Shape definitions are not serialized by saveToString, and the applet will show rectangles if the shape identifiers it loads do not match existing shapes. In addition to the DiagramData param, try adding a ShapeLibrary param whose value is set to the shape library file's URL; that should load your custom shapes before loading the diagram nodes and render them correctly.
JR
Reply #2 - Nov 28th, 2013 at 11:52am
Great, it works !! Smiley
Juan
