Hot Topic (More than 10 Replies) Australian Holidays? (Read 9338 times)
TRB
Meppy knows all!!
Jan 2nd, 2014 at 11:30pm
Hi Meppy,
I think the subject says it all but I will ask anyway.
Is there an Australian Holiday Provider and if there is how do i access/use it and if there isn't is there a way i could achieve the same results?
I have concidered syncing with the Outlook calendar but this isn't exactly what i want.
Any advice would be appreciated Smiley
TRB
Re: Australian Holidays?
Reply #1 - Jan 6th, 2014 at 7:26am
Currently we only have an US holidays provider. If you can provide the information how Australian holidays are calculated, we can implement them in a new provider. Alternatively you can implement the IHolidayProvider interface yourself.
Reply #2 - Jan 6th, 2014 at 9:12am
We added a new provider for the national Australian holidays. You can find the updated HolidayProviders library attached to this post.
MindFusion_HolidayProviders.zip (Attachment deleted)
TRB
Meppy knows all!!
Reply #3 - Jan 6th, 2014 at 9:21am
Thank you so much Meppy!!! I dont know how you do it so fast!! Thanks Again.
TRB
TRB
Meppy knows all!!
Reply #4 - Jan 6th, 2014 at 9:40am
I Just Checked them out. They are spot on...Thanks again.
TRB
TRB
Meppy knows all!!
Reply #5 - May 1st, 2016 at 4:57am
Sorry to revive an old thread however I would like to know what to do when the holidays are changed. Can I update/add to the Holiday provider somehow?
Thanks Undecided
TRB
Reply #6 - May 3rd, 2016 at 9:11am
It is currently not possible to customize the existing holiday providers unless you possess the source code. Let me know what you need to change and I'll see if we can make the providers extendable.
TRB
Meppy knows all!!
Reply #7 - May 4th, 2016 at 4:21am
I was hoping the user could input local holidays (like show day) and also there are a number of State specific holidays which it would be nice to have the option to add.  Shocked
TRB
Reply #8 - May 4th, 2016 at 8:50am
Check out this version of the HolidaysProvider library:
https://mindfusion.eu/_temp/MindFusion.HolidayProviders.zip
The GetHolidays methods are now virtual and can be overridden. To add (or remove) new holidays from the result, override the respective GetHolidays method and modify the returned array.
Let me know if this helps.
TRB
Meppy knows all!!
Reply #9 - May 14th, 2016 at 1:47am
Thanks Meppy,
            I'm having trouble understanding how to perform this. It's obviously a lack of understanding on my part. Is it to much to ask for an example of how this is done? Embarrassed
TRB
Reply #10 - May 16th, 2016 at 7:16am
Check out this sample:
https://mindfusion.eu/_samples/_sample_Holidays.zip
It illustrates how to create a custom holiday provider in order to customize the holidays returned by an existing provider.
TRB
Meppy knows all!!
Reply #11 - May 17th, 2016 at 6:58am
The support you guys offer is second to none!! Thank you so much! Wink
TRB
