Normal Topic DeserializeTag not raised when loading DiagramDocument (Read 1648 times)
Dominic
Jan 20th, 2014 at 1:08pm
I try to use the DeserializeTag event when loading an DiagramDocument:
var dd = new DiagramDocument();
dd.DeserializeTag += MyDeserializer;
dd.LoadFromXml("myFile");
But the event is not raised.
I assume the event is raised only on the DiagramPage instance, not the DiagramDocument. Can you help me?
Dominic
Re: DeserializeTag not raised when loading DiagramDocument
Reply #1 - Jan 20th, 2014 at 4:40pm
If you have the control's source code, find the page.LoadFromXml call in DiagramDocument.LoadFromXml, and set EventTarget = this just above it:
page.EventTarget = this;
page.LoadFromXml(document, diagramElement);
// for single diagram xml too:
singlePage.EventTarget = this;
singlePage.LoadFromXml(document, rootElement);
This fix will be available in version 3.0.4 we are now releasing.
Dominic
Reply #2 - Jan 21st, 2014 at 4:47pm
Thanks, this is what I needed.
