Normal Topic Shapes with fixed proportional drawing of angles (Read 1769 times)
Lothar Behrens
Mar 7th, 2014 at 3:33am
I have searched all the samples, but I didn't found one.
Based on the Arrow1 in the 'Complex box samples' I like to keep the angel of the right side fixed when I resize the shape.
Reason is to draw a process map where several books show those fixed angles and it looks ugly if not.
Like this one: http://de.wikipedia.org/w/index.php?title=Datei:Wkd_wkd_produktionsunternehmen1....;
The angle could be calculated by the height of the shape, or better made up with a control point.
How can I do this?
Thanks, Lothar
Re: Shapes with fixed proportional drawing of angles
Reply #1 - Mar 7th, 2014 at 5:31am
That can be done using a shape formula. You can find some examples that also add control points to shapes here:
http://mindfusion.eu/Forum/YaBB.pl?num=1376129632/2#2
http://mindfusion.eu/blog/?p=507
