Normal Topic Change the grid lines in a SwimlaneLayout (Read 2522 times)
Tom
Apr 2nd, 2014 at 6:28pm
How can I change the color of the gridlines in a Swimlane layout?
I'm new to this so a code sample would be much appreciated.
Tom
Re: Change the grid lines in a SwimlaneLayout
Reply #1 - Apr 2nd, 2014 at 6:50pm
Try this:
Style s = diagram.LaneGrid[null, null].Style;
s.LeftBorderPen =
	s.TopBorderPen =
		s.RightBorderPen =
			s.BottomBorderPen =
				new Pen(Color.Red);
Tom
Reply #2 - Apr 3rd, 2014 at 7:08pm
Thanks for this. This works fine in c#. I'm working in another language with imperfect support of the CLR. One of the limitations is that it can't access a property with more than one index. Now it was easy for me to write a quick C# dll to work around this but I would like to know if there's an alternative that does not require me to use a dual indexed property?
Tom
Reply #3 - Apr 4th, 2014 at 10:38am
There is no other way to access it using the public API. You could use .NET reflection instead if your language allows it:
Type headerType = typeof(MindFusion.Diagramming.Lanes.Header);
Type gridType = typeof(MindFusion.Diagramming.Lanes.Grid);
PropertyInfo cellProperty = gridType.GetProperty(
	"Item", new Type [] { headerType, headerType });
ICell cellRange = (ICell)cellProperty.GetValue(
	diagram.LaneGrid, new object[] { null, null });
Style s = cellRange.Style;
s.LeftBorderPen =
	s.TopBorderPen =
		s.RightBorderPen =
			s.BottomBorderPen =
				new Pen(Color.Red);
« Last Edit: Apr 7th, 2014 at 1:56pm by Stoyo »
Tom
Reply #4 - Apr 5th, 2014 at 12:25pm
Thanks so much. This was very helpful and I was able to make it work.
Tom
