Normal Topic Html export possible (Read 4608 times)
Jonbr
May 7th, 2014 at 1:43pm
Hi all, I have a document in xlsx format. I'm working on an app that should perform regular updates to this document, preferably in a visual environment, and export the result to html. Is this possible to do with your component?
Greets,
JonBr.
Re: Html export possible
Reply #1 - May 7th, 2014 at 2:36pm
We do not currently provide exporting to HTML, but we have this planned for the next release of the control.
Jonbr
Reply #2 - May 8th, 2014 at 7:27am
Hi Meppy, is there an expected date for the release?
Reply #3 - May 8th, 2014 at 9:50am
We don't have a set date for the next release. It will probably be out the next month.
Jonbr
Reply #4 - May 9th, 2014 at 10:21am
Thanks, looking forward to it.
JonBr.
Reply #5 - May 14th, 2014 at 11:17am
We have added HTML and MHTML exporters to the Spreadsheet component. A new version of the Demo and the updated assemblies can be downloaded from the following link:
http://mindfusion.eu/_temp/_sample_SpreadsheetDemo.zip
You can access the new exporters from the File->Export menu.
Jonbr
Reply #6 - May 15th, 2014 at 6:03am
Hi Meppy, thank you very much.
Jonbr
Reply #7 - May 15th, 2014 at 6:58am
Hi Meppy, the exporter looks good so far. However, the documents I operate with can contain dozens, sometimes even hundreds of sheets. Exporting all sheets in one file results in a huge HTML that is hard to manage. Ideally, I would want to export sheets to separate files or at least have an option to export individual sheets.
Greets,
JonBr.
Reply #8 - May 19th, 2014 at 6:04am
Have a look at the updated version of the assemblies:
http://mindfusion.eu/_samples/_sample_SpreadsheetDemo.zip
You can use the new FromWorksheet and ToWorksheet properties of the exporter class to specify which worksheets to export.
Jonbr
Reply #9 - May 21st, 2014 at 9:24am
Meppy, the new properties work great, thanks!
