Normal Topic Save to xml only the part of the diagram (Read 1223 times)
Hunter
Jun 4th, 2014 at 1:59pm
Hello.
Is there any way to save into xml part of the diagram. For example I need to save some nodes and links but exlude another nodes. Now I see only one way: create new Diagram object, add into this object necessary DiagramItems and call Diagram.SaveToXml().
Re: Save to xml only the part of the diagram
Reply #1 - Jun 4th, 2014 at 3:35pm
Yes, you will have to use a second diagram. If you need to save selected objects, it's easy to copy them to the temporary diagram using CopySelection and PasteSelection methods as in http://mindfusion.eu/Forum/YaBB.pl?num=1276638873/5#5
