Normal Topic links without HeadShape show up as PointerArrow after save. (Read 2886 times)
Blue
Jun 23rd, 2014 at 1:13pm
I'm using Diagramming for ASP.NET, V5.0.5
When i'm using link.setHeadShape(null) clientside it works as expected and removes the head shape from the link.
When the map is saved serverside and reloaded, the same link shows up as having a PointerArrow. The clientside model seems to get this shape automatically if the headshape is null serverside.
When I view the map after it's saved using imagemap mode instead the arrow head is not visible.
Any fix for this?
Re: links without HeadShape show up as PointerArrow after save.
Reply #1 - Jun 24th, 2014 at 9:15am
Call this from body.onload handler as work-around:
function onLoad()
	var linkFromJson = MindFusion.Diagramming.DiagramLink.prototype.fromJson;
	MindFusion.Diagramming.DiagramLink.prototype.fromJson = function(json) {
		linkFromJson.apply(this, [json]);
		if (!json.headShape)
			this.setHeadShape(null);
Blue
Reply #2 - Jun 24th, 2014 at 4:17pm
Hi, thanks again! Yes the following works.
Code (Javascript)
// Fixes empty link Head Shapes showing up as having arrows
Sys.Application.add_load(function () {
    var linkFromJson = window.MindFusion.Diagramming.DiagramLink.prototype.fromJson;
    window.MindFusion.Diagramming.DiagramLink.prototype.fromJson = function (json) {
I got some other small issues that probably should be fixed. Should I send you a PM or post them in the forums?
Reply #3 - Jun 25th, 2014 at 7:07am
As you wish.
