Normal Topic in the js version zoom zooms overview not the canvas (Read 3296 times)
agelospanagiotakis
Jun 24th, 2014 at 9:16am
I have a problem the following functions
zoom the overview not the canvas
Code (Javascript)
function onZoomIn(diagramName) {
    var diagram = $find(diagramName);
    console.log(diagram);
    if (diagram.zoomFactor > 200) return;
    diagram.setZoomFactor(diagram.zoomFactor + 10);
function onZoomOut(diagramName) {
    if (diagram.zoomFactor < 19) return;
    diagram.setZoomFactor(diagram.zoomFactor - 10);
function onZoomToFit(diagramName) {
    diagram.zoomToFit();
Code (HTML)
 <a onclick="javascript:onZoomIn('ProblemTreeDiagram');" class="btn btn-primary" title="Zoom In">
                                        <span class="glyphicon glyphicon-zoom-in"></span>
                                    </a>
                                    <a onclick="javascript:onZoomOut('ProblemTreeDiagram');" class="btn btn-primary" title="Zoom Out">
                                        <span class="glyphicon glyphicon-zoom-out"></span>
                                    </a>
                                    <a onclick="javascript:onZoomToFit('ProblemTreeDiagram');" class="btn btn-primary" title="Zoom Out">
                                        <span class="glyphicon glyphicon-fullscreen"></span>
                                    </a>
<div id="PToverviewContainer">
                        <div style="width: 100%; height: 100%; overflow: none; border: 0px solid rgb(0, 0, 0);margin-left: auto;margin-right: auto;">
                            <canvas id="PTDiagramOverview" width="100%" height="100%"></canvas>
                        </div>
                    </div>
 <div id="ProblemTreeDiagramDiagramContainer" class="diagramContainer" style="width: 100%; height: 650px; overflow: auto; border: 0px solid;">
                                <canvas id="ProblemTreeDiagram" width="100%" height="100%">This page requires a browser that supports HTML 5 Canvas element.
                                </canvas>
                            </div>
Re: in the js version zoom zooms overview not the canvas
Reply #1 - Jun 24th, 2014 at 10:17am
I imagine something similar will happen if you create Diagram and Overview instances with swapped DOM Canvases. Could you post your initialization code with all $create calls?
agelospanagiotakis
Reply #2 - Jul 3rd, 2014 at 11:04am
Actually this happens due to these commands
Code (Javascript)
hh = getHeight(PTDiagram);//actually hh = lastNodeBounds.y + lastNodeBounds.height;
$("#ProblemTreeDiagram").height(hh);
$("#ProblemTreeDiagramDiagramContainer").height(hh);
Code (HTML)
                        <div style="width: 100%; height: 100%; overflow: none; border: 0px solid rgb(0, 0, 0); margin-left: auto; margin-right: auto;">
                            <canvas id="PTDiagramOverview" style="min-width: 357px; min-height: 134px;"></canvas>
                        </div>
                    </div>
                                <canvas id="ProblemTreeDiagram" width="100%" height="650px">This page requires a browser that supports HTML 5 Canvas element.
                                </canvas>
                            </div>
Cheesy weird isn't it ?
Reply #3 - Jul 3rd, 2014 at 12:54pm
If getHeight() returns the bottom coordinate of some node, you might have to convert from the default millimeter MeasureUnit to pixels before calling $.height(). If you are trying to make the container div large enough to fit the whole diagram, you could call diagram.resizeToFitItems(), then get the pixel size of the Canvas element, and assign it to the container Div.
agelospanagiotakis
Reply #4 - Jul 8th, 2014 at 10:41am
Thank you stoyan for all your guidance and help
