Normal Topic Control the Arrow-Position and Arrow-Direction (Read 4116 times)
zhang
Jun 24th, 2014 at 3:17pm
Hello, my question is, how can I control the LinkHead(Arrow), I explain this with the following code and 2 pictures. The Arrow-position seems to can not be always in the middle of the NodeRecht, and the Arrow-direction is wrong. could you tell me,is it possible to change that? thank you very much!
DiagramLink dl=diagram2.getFactory().createDiagramLink(origin, target);
                  dl.setHeadShape(Shape.fromId("Arrow3"));
dl.setHeadShapeSize(3);
Re: Control the Arrow-Position and Arrow-Direction
Reply #1 - Jun 24th, 2014 at 5:32pm
You should use shapes from the ArrowHeads enumeration:
http://www.mindfusion.eu/onlinehelp/droiddiagram/index.htm?T_com_mindfusion_diag...
If you want one looking like the Arrow3 box shape, use a custom definition:
new Shape(
            new ElementTemplate[]
                new LineTemplate(0, 40, 50, 0),
                new LineTemplate(50, 0, 100, 40),
                new LineTemplate(100, 40, 70, 40),
                new LineTemplate(70, 40, 70, 100),
                new LineTemplate(70, 100, 30, 100),
                new LineTemplate(30, 100, 30, 40),
                new LineTemplate(30, 40, 0, 40)
            Path.FillType.WINDING, "MyArrow");
zhang
Reply #2 - Jun 24th, 2014 at 7:07pm
Thanks, but I still can not change the position of the Arrow, as the following picture, when the diagram be created, the LinkHead's (Arrow's) position is automatically be set, it looks not very correct. could you tell me may I change the position to the left-middle of Rechtangle? Is it possible? Thank you very much indeed!
Reply #3 - Jun 25th, 2014 at 7:56am
Set nodes' AnchorPattern property, and set Anchoring property of layout classes to either Keep or Reassign before calling Arrange. You might also check the AnchorPoints sample project to see how to define custom connection points.
zhang
Reply #4 - Jun 25th, 2014 at 4:22pm
thanks a lot.
