Normal Topic Override default paste from keyboard (Read 1255 times)
PDM.
Senior Member
Jul 17th, 2014 at 5:37am
By default i see component allow to copy and paste trough clasical and standard hot keys, ctrl +c and ctrl +v
I add this code:
private void formkeydown(object sender, KeyEventArgs e)
if (Keyboard.IsKeyDown(Key.LeftCtrl) && Keyboard.IsKeyDown(Key.V))
form.PasteFromClipboard(new Vector(20, 20));
e.Handled = true;
Anyway this not work, new node paste arround 8 pixels x y moved form original node.
Some sugestion?
Re: Override default paste from keyboard
Reply #1 - Jul 17th, 2014 at 10:09am
You can override the built-in paste command like this:
diagram.CommandBindings.Add(new CommandBinding(ApplicationCommands.Paste,
	(sender, args) => diagram.PasteFromClipboard(offset)));
