Normal Topic About charset 'GBK' ? (Read 3152 times)
Frank
Jul 24th, 2014 at 3:07am
Hello everybody, I'm trying to develop a C# Winform application to display flowcharts on MindFusion for Winform(trial). When I created ShapeNodes with the label in Chinese characters, they are displayed in unknown chars. It seems to be a problem of charset converting. The default charset of my platform is GBK.
By the way, I can read the correct characters before passing them to the attribute 'ShapeNode.Text' while debugging. I tried to convert them to the 'UTF8' and 'Unicode' charset before passing them to that attribute, but it did not work. And it confused me that the Chinese characters charset are supported on MindFusion or not, and how I can do with it ?
I would be thankful to any help on this issue.
Re: About charset 'GBK' ?
Reply #1 - Jul 24th, 2014 at 4:47am
Try solution from http://mindfusion.eu/Forum/YaBB.pl?num=1287546110/1#1
Reply #2 - Jul 24th, 2014 at 4:50am
This Topic was moved here from ASP.NET [move by] Forum Admin.
Frank
Reply #3 - Jul 25th, 2014 at 12:47am
Thanks a lot.
As you suggested, I fixed it by setting the font name to "Arial Unicode MS".
