Normal Topic Customizing distance between the unconnected ContainerNodes (Read 1521 times)
mihai
Aug 4th, 2014 at 12:27pm
I'm trying to specify the horizontal distance between unconnected ContainerNodes, but the LayeredLayout.LayerDistance doesn't seem to help. If I understand correctly, the NodeDistance property won't help me here, because these nodes end up in different layers. By the way, I've set the MultipleGraphsPlacement to Horizontal.
Any suggestions?
-Mihai
Re: Customizing distance between the unconnected ContainerNodes
Reply #1 - Aug 4th, 2014 at 3:49pm
Set the LayeredLayout.Margins property; it specifies margin size around each subgraph.
mihai
Reply #2 - Aug 4th, 2014 at 6:32pm
That worked, thanks Stoyan!
