Normal Topic Anchoring nodes inside containers (Read 2912 times)
mihai
Aug 6th, 2014 at 7:34am
Is there support to anchor child nodes inside container nodes, so that they potentially resize with the container? That is, similar to Control.Anchor in WinForms.
-Mihai
Re: Anchoring nodes inside containers
Reply #1 - Aug 6th, 2014 at 8:38am
There's support for that in the Group class used by Containers to manage their children. We'll add an Add(GroupAnchorStyles) overload for next release to let you create respective type of grouping. For time being you could use child.AttachTo(container,GroupAnchorStyles) method, but it won't support some container features, such as folding.
mihai
Reply #2 - Aug 7th, 2014 at 9:14am
Understood. Thanks Stoyan, on both counts.
Reply #3 - Aug 14th, 2014 at 11:19am
This version implements a ContainerNode.Add(GroupAnchorStyles) overload:
https://mindfusion.eu/_beta/wpfdiag_ctranchor.zip
You can use it like this to anchor to lower right corner for example:
var ctr = diagram.Factory.CreateContainerNode(10, 10, 200, 200);
ctr.EnabledHandles = AdjustmentHandles.All;
ctr.HandlesStyle = HandlesStyle.DashFrame;
var node = diagram.Factory.CreateShapeNode(120, 120, 50, 50);
ctr.Add(node, GroupAnchorStyles.Right | GroupAnchorStyles.Bottom);
mihai
Reply #4 - Aug 22nd, 2014 at 8:13am
Nice, thanks Stoyan!
