Normal Topic DiagramLink Draw() Pen flicker (Read 2105 times)
j poz
Aug 11th, 2014 at 3:23pm
I am overriding the Draw() method of DiagramLink, and doing something like this:
public override void Draw(MindFusion.Drawing.IGraphics graphics, RenderOptions options)
             if (DragOver)
                Pen = YellowPen;
                HeadPen = YellowPen;
            else
                Pen = BlackPen;
                HeadPen = BlackPen;
             base.Draw(graphics, options);
The problem is that when DragOver is true, the link is being drawn in yellow but flickering between black and yellow as I drag over it.
How do I stop it from flickering like this?
Re: DiagramLink Draw() Pen flicker
Reply #1 - Aug 12th, 2014 at 2:19pm
You might be seeing the black color from the view's bitmap buffer used for fast redrawing of stationary items during modification of the active item. Try calling the RecreateCacheImage method from each NodeModifying event if you set the DragOver flag while moving nodes, or better call it only when a link has to be redrawn because a node moves over / away from it.
j poz
Reply #2 - Aug 12th, 2014 at 4:48pm
You're right, that was it. Thank you.
