Normal Topic Timetable - Change SubHeaderStyle (Read 5262 times)
TimKras
Aug 22nd, 2014 at 1:47pm
Is it possible to add an image to the Header of a TimeTable?
Re: Timetable - Change SubHeaderStyle
Reply #1 - Aug 22nd, 2014 at 2:28pm
You can provide a custom template for the column headers in the Timetable view as illustrated by the following example:
https://mindfusion.eu/_samples/_sample_CustomTimetableHeader.zip
The example uses the recently added ColumnHeaderTemplate property. If this property is not available in the latest official release of the control, you can use the assembly contained in the sample.
Let me know if this helps.
Meppy.
TimKras
Reply #2 - Aug 23rd, 2014 at 6:23pm
Thank you for the fast answer.
I did not mention i use the Timetable with GroupType="GroupByResources" and MainHeaderSize="0".
So I want to provide a custom template for a SubHeader if possible.
Reply #3 - Aug 25th, 2014 at 8:07am
We have added a new property (ColumnSubheaderTemplate) to the TimetableSettings class, which lets you customize the appearance of the sub-headers in the Timetable view. An updated version of the sample, which illustrates the new property, can be downloaded from the link below:
https://mindfusion.eu/_samples/_sample_CustomTimetableHeader2.zip
TimKras
Reply #4 - Aug 25th, 2014 at 6:44pm
Thank you.
Now it will fit the requirements.
