Normal Topic Can I change the position of digram components like Links, Decision box and the Font of the text wri (Read 4881 times)
Ikshita
Aug 28th, 2014 at 6:14am
I am new to MindFusion. I tried some of the examples and tutorials. The diagram generated are positioned on its own. Are there some parameters which can fix the position of components. also can I change the Font of the text written?
Re: Can I change the position of digram components like Links, Decision box and the Font of the text wri
Reply #1 - Aug 28th, 2014 at 8:26am
You can change item positions and fonts programmatically like this:
var Rect = MindFusion.Drawing.Rect;
var Point = MindFusion.Drawing.Point;
var Font = MindFusion.Drawing.Font;
node.setBounds(new Rect(100, 10, 30, 20));
link.setStartPoint(new Point(55, 10));
link.setEndPoint(new Point(115, 10));
link.route();
node.setText("test");
node.setFont(new Font("sans-serif", 8));
If you need to also specify positions of link bend points, you could modify the array returned by DiagramLink.getControlPoints() and then call link.updateFromPoints().
Font size is specified in current MeasureUnit, i.e. millimeters by default.
Ikshita
Reply #2 - Aug 28th, 2014 at 10:41am
Hi Stoyan,
Thanks for the reply. The font part worked.
For positioning the diagram components:
I am reading the parameters from a text file.
My js is: Tutorial5Iks.js
var Events = MindFusion.Diagramming.Events;
var Diagram = MindFusion.Diagramming.Diagram;
var DiagramLink = MindFusion.Diagramming.DiagramLink;
var ShapeNode = MindFusion.Diagramming.ShapeNode;
var AnchorPattern = MindFusion.Diagramming.AnchorPattern;
var AnchorPoint = MindFusion.Diagramming.AnchorPoint;
var MarkStyle = MindFusion.Diagramming.MarkStyle;
var GlassEffect = MindFusion.Diagramming.GlassEffect;
var LayeredLayout = MindFusion.Graphs.LayeredLayout;
var diagram = null;
var decision1In3Out, apat2;
Sys.Application.add_load(function (sender, args)
     // create a Diagram component that wraps the "diagram" canvas
     diagram = $create(Diagram, null, null, null, $get("diagram"));
     // register event handlers
     //diagram.addEventListener(Events.nodeCreated, onNodeCreated);
     // pretent we are calling a web service
var request = new Sys.Net.WebRequest();
request.set_url("Tutorial5Iks.txt");
request.set_httpVerb("GET");
request.add_completed(onResponse);
request.invoke();
function onResponse(executor, eventArgs)
    if (executor.get_responseAvailable)
        var json = executor.get_responseData();
        var graph = Sys.Serialization.JavaScriptSerializer.deserialize(json);
        buildDiagram(graph);
function buildDiagram(graph)
    var nodeMap = [];
    var bounds = new Rect(20, 78, 60, 18);
           var blue = "#0000FF";
     var green = "#00FF00";
     var red = "#FF0000";
    // load node data
    var nodes = graph.nodes;
    Array.forEach(nodes, function (node)
        var diagramNode = diagram.getFactory().createShapeNode(bounds);
        nodeMap[node.id] = diagramNode;
            diagramNode.setText(node.name);
           diagramNode.setShape(node.shape);
           diagramNode.setFont(new Font("sans-serif", 4));
             diagramNode.setBrush(node.color);
    // load link data
    var links = graph.links;
    Array.forEach(links, function (link)
      var diagramNode =   diagram.getFactory().createDiagramLink(
            nodeMap[link.origin],
            nodeMap[link.target]);
                 diagramNode.setText(link.name);
           // arrange the graph
var layout = new LayeredLayout();
layout.nodeDistance = 10;
layout.layerDistance = 10;
diagram.arrange(layout);
And the text I am reading is :
{"nodes":[
     {"id":0,"name":"Start","shape":"Circle","color":"green"},
    {"id":1,"name":"Leave Request Created","shape":"Rectangle","color":"LightCyan"},
     {"id":2,"name":"Review By Approver","shape":"Rectangle","color":"LightCyan"},
    {"id":3,"name":"Is Leave Request Approved?","shape":"Decision","color":"LightCyan"},
    {"id":4,"name":"Approved by Approver 2","shape":"Rectangle","color":"LightCyan"} ,
     {"id":5,"name":"End","shape":"Circle","color":"green"},
"links":[
    {"origin":0,"target":1},
      {"origin":1,"target":2},
      {"origin":2,"target":3},
      {"origin":3,"target":4,"name":"No"},
      {"origin":3,"target":5,"name":"Yes"}
Now I want to somehow pass the value of positioning the components through the text file. Please help me with this.
Reply #3 - Aug 28th, 2014 at 10:55am
You could add x,y,width,height attributes to the nodes' JSON, and create the initial bounds from them:
 {"id":0,"name":"Start","x":5,"y":5,"w":20,"h":20,"shape":"Circle","color":"green"},
        var nodeBounds = new Rect(node.x, node.y, node.w, node.h);
        var diagramNode = diagram.getFactory().createShapeNode(nodeBounds);
with similar processing for links' startx,starty,endx,endy attributes, passing them as setStartPoint and setEndPoint coordinates after creating a link.
Remove the LayeredLayout code from buildDiagram function if you will be using fixed coordinates.
Ikshita
Reply #4 - Aug 28th, 2014 at 1:28pm
Hi Stoyan,
Thanks for the code. I am not sure what I am doing wrong.
js:
var diagram = null;
request.invoke();
    var nodeMap = [];
    // load node data
     //var nodeBounds = new Rect(node.x, node.y, node.w, node.h);
        var diagramNode = diagram.getFactory().createShapeNode(node.bounds);
    // load link data
           //      link.setStartPoint(new Point(link.startpointx, link.startpointy));
                 //link.setEndPoint(new Point(link.endpointx, link.endpointy));
diagram.arrange(layout);*/
txt:
{"nodes":[
     {"bounds":"new Rect(20, 35, 30, 20)","id":0,"name":"Start","shape":"Circle","color":"green"},
    {"bounds":"new Rect(70, 30, 30, 20)","id":1,"name":"Leave Request Created","shape":"Rectangle","color":"LightCyan"},
"links":[
with this I am getting error:
TypeError: D.getBounds(...).clone is not a function
I also tried setting x,y,w,h parameters for rectangles and startx,starty,endx,endy parameters for links. But somehow it is not working.
Reply #5 - Aug 28th, 2014 at 3:37pm
I don't think you can use JavaScript expressions like "new Rect(20, 35, 30, 20)" as JSON vaues, unless you pass them through the eval function first. You can find attached my test page with above code (setting individual coordinate attributes), it seems to work fine.
tutorial1_-_copy.zip (Attachment deleted)
Ikshita
Reply #6 - Sep 1st, 2014 at 6:34am
Hi Stoyan,
Thanks a ton. It worked  Smiley . I was passing  x,y,w,h parameters with "" ,due to this my diagram was not rendered.
{"id" :0, "x" :"10","y":"10","w":"10","h":"10"} .
I replaced it without quotes and it worked.
Thanks again  Smiley
