Normal Topic routeAllLinks for cascading only? (Read 2050 times)
Al
Sep 9th, 2014 at 10:09am
It seems that using 'routeAllLinks' forces all links to be cascading, is this correct?
Re: routeAllLinks for cascading only?
Reply #1 - Sep 9th, 2014 at 10:44am
It does not change link.Shape to Cascading per se, but the link router only supports strictly horizontal and vertical path segments at this time, and will assign them even to polyline and Bezier links. If you move a control point interactively after routing, the link should still apply respective shape rules, e.g. letting you set acute angles for polyline links.
Al
Reply #2 - Sep 9th, 2014 at 1:36pm
ok, tx
