Normal Topic Begin node edit via mouse, keypress combo (Read 2125 times)
Chris M
Oct 7th, 2014 at 7:31pm
I am trying to start in-place editing of a node via the below code, however, it's not working and in the debugger e.MouseButton always equals None.  Can you please advise? Thanks.
Private Sub diagram_NodeSelecting(sender As Object, e As NodeValidationEventArgs) Handles diagram.NodeSelecting
        If (e.MouseButton = MouseButton.Right AndAlso My.Computer.Keyboard.AltKeyDown) Then
            diagramView1.BeginEdit(e.Node)
        End If
    End Sub
Re: Begin node edit via mouse, keypress combo
Reply #1 - Oct 8th, 2014 at 7:46am
MouseButton is only reported for click and double-click events, so you could start editing from NodeClicked handler:
Private Sub diagram_NodeClicked(ByVal sender As System.Object, ByVal e As MindFusion.Diagramming.NodeEventArgs) Handles diagram.NodeClicked
    End If
End Sub
