Normal Topic how to set some selected-nodes auto align(such as Left-Align.Center-Align. Top-Align) in Diagram? (Read 2201 times)
heyx
Oct 13th, 2014 at 5:43am
hello,
    after I create some nodes in Diagram,then I selected some of them. and I want to set the Selected-Nodes auto align.
the align mode include left-align,right-align,center-align,top-align,bottom-align,Middle-align.
could you tell me is there some method to reach the effect?
thank!
Re: how to set some selected-nodes auto align(such as Left-Align.Center-Align. Top-Align) in Diagram?
Reply #1 - Oct 13th, 2014 at 8:45am
You can find some sample code here:
http://mindfusion.eu/Forum/YaBB.pl?num=1412696051
That code is for Windows Forms; replace all RectangleF with Rect and float with double to compile under WPF. Centering using the methods above will look like this:
void AlignCenterX()
	Align(
		r => r.X + r.Width / 2,
		(r, coord) => new Rect(coord - r.Width / 2, r.Y, r.Width, r.Height));
void AlignCenterY()
	Align(
		r => r.Y + r.Height / 2,
		(r, coord) => new Rect(r.X, coord - r.Height / 2, r.Width, r.Height));
void Align(
	Func<Rect, double> getter,
	Func<Rect, double, Rect> setter)
	var target = diagram.ActiveItem as DiagramNode;
	if (target != null)
		var alignedCoord = getter(target.Bounds);
		foreach (var node in diagram.Selection.Nodes)
			if (node == target)
				continue;
			node.Bounds = setter(node.Bounds, alignedCoord);
void AlignLeft()
	Align(
		r => r.Left,
		(r, coord) => new Rect(coord, r.Y, r.Width, r.Height));
void AlignTop()
	Align(
		r => r.Top,
		(r, coord) => new Rect(r.X, coord, r.Width, r.Height));
void AlignRight()
	Align(
		r => r.Right,
		(r, coord) => new Rect(coord - r.Width, r.Y, r.Width, r.Height));
void AlignBottom()
	Align(
		r => r.Bottom,
		(r, coord) => new Rect(r.X, coord - r.Height, r.Width, r.Height));
heyx
Reply #2 - Oct 13th, 2014 at 9:28am
thanks,It works.
