Hot Topic (More than 10 Replies) Node text is always bold (Read 7200 times)
Al
Nov 5th, 2014 at 9:45am
I have tried setting a specific font as below but my text always appears bold
Code (Javascript)
var Font = MindFusion.Drawing.Font;
diagramNode.setFont(new Font("Arial", 8 * 25.44 / 72, false, false));
Re: Node text is always bold
Reply #1 - Nov 5th, 2014 at 11:19am
It doesn't look bold in our test page. Check if you aren't assigning a bold font later on.
Al
Reply #2 - Nov 5th, 2014 at 12:29pm
It is strange, you can see from my screenshot that the text 'Closed' just above the mindfusion diagram is different to the node text - and they are both arial(8).
In the console when I run
Code (Javascript)
diagram.elements[0].item.font
I get
Code (Javascript)
a.Font {name: "Arial", size: 2.8266666666666667, bold: false, italic: false, toString: function}function}
So it is definitely set correctly on my node. I can't see that anything else could affect this.
Reply #3 - Nov 5th, 2014 at 1:49pm
In what browser are you seeing this?
Al
Reply #4 - Nov 5th, 2014 at 3:15pm
Chrome(38),  IE looks a bit better but I'm still not certain that it is right.
Reply #5 - Nov 6th, 2014 at 9:03am
Chrome does not show it bold for me, but with hardware acceleration it might depend on how the video card handles font scaling applied for diagram's MeasureUnit. To avoid scaling try setting MeasureUnit to Pixel or Point, and specify larger values for node and font sizes.
Al
Reply #6 - Nov 6th, 2014 at 9:33am
Please show me how - is this on the canvas element or a property of diagram.xxxx ?
Reply #7 - Nov 6th, 2014 at 10:25am
It's a Diagram property inherited from base MindFusion.Drawing.Canvas class:
var GraphicsUnit = MindFusion.Drawing.GraphicsUnit;
diagram.setMeasureUnit(GraphicsUnit.Pixel);
Al
Reply #8 - Nov 6th, 2014 at 2:48pm
It definitely gets smaller using point, both versions seem to have some weird spacing though & all other text on my page using the same font displays just fine.
Reply #9 - Nov 7th, 2014 at 9:01am
It seems Chrome applies some anti-aliasing and the text looks bolder when drawing text on non-white background:
<html>
<body>
<div style="font:10pt Arial">
test test
</div>
<canvas ID="myCanvas">
<script>
var c=document.getElementById("myCanvas");
 var ctx=c.getContext("2d");
 ctx.fillStyle="gray"
 ctx.fillRect(0, 0, 200, 200)
 ctx.font="10pt Arial";
 ctx.fillStyle="white"
 ctx.fillText("test test",10,50);
</script>
 </body>
 </html>
The div and canvas texts look the same in IE, but canvas one is bolder in Chrome, while if you remove the fillStyles to draw black on white it looks the same in both browsers. You might also be getting different font sizes in HTML and Canvas. Our font class assumes font size in pixels and appends px suffix; you could replace this method with your own version if you want to specify fonts in other unit:
Font.prototype.toString = function ()
	var font = ""
	if (this.bold)
		font += 'bold ';
	if (this.italic)
		font += 'italic ';
	font += this.size + 'px ' + this.name;
	return font;
You should also set MeasureUnit to Pixel to avoid additional scale transform applied by the diagram.
Al
Reply #10 - Nov 7th, 2014 at 1:27pm
Thanks Stoyan, using GraphicsUnit.Pixel worked just fine - this won't cause any problems on different screen resolutions right?
Reply #11 - Nov 7th, 2014 at 6:30pm
pixel is supposed to be device-independent unit in browsers (see reply in http://stackoverflow.com/questions/21680629/getting-the-physical-screen-dimensio...), so it should not cause problems.
