We have released version 1.1.1 of MindFusion.Diagramming for Android. It contains the following improvements:
Improved arrowhead rendering~ Arrowheads are rendered as a single path when possible and several arrowhead Shape definitions have been changed to implement mitered joints when HeadPen is set to a thick pen.
~ The point where end segments connect to arrowheads can be specified via the LinkSegmentInset property of shapes. Shape definitions from the ArrowHeads class set it to suitable default value. This allows using transparent or semi-transparent brushes without seeing the link line drawn behind arrowheads.
~ Arrowhead shadows are no longer filled if the link's EffectiveBrush is null or fully transparent.
~ IntermediateShape is now also rendered for Bezier links.
Miscellaneous~ Link segments and node borders are now drawn anti-aliased.
~ Improved DiagramLink rendering speed.
~ Improved text layout in TextComponent and LinkLabel.
~ Fixed null-reference exception in some situations when tap is outside of diagram boundaries.
clients area on our site.
https://www.mindfusion.eu/DroidDiagramTrial.zip Enjoy!
