Normal Topic strange behaviour in swimlane (Read 2257 times)
Michael
Dec 2nd, 2014 at 1:24pm
Hallo
IŽm using a diagram with a swimlane diagram view. The grid of the diagram is a lane grid.
The diagram has three columns that get filled programmatically.
The first time the diagram gets filled with nodes and links everything looks like it should.
After clearing the content of the diagram with ClearAll() and refilling it with ch anged (e.g. only two of the columns are filled with nodes) content, everything is still looking fine. The error behavior comes with the third filling when the look changes completely (the third column has a black stroke and the links are shortened) and I canŽt localize the issue why.
Do you have any idea what can change in the code to get it work properly?
Attached youŽll find three pictures and the code behind of my diagram control.
Thank you very much.
Here is the Code
using System;
using System.Drawing;
using System.Linq;
using System.Windows.Forms;
using IBS.Common.Enums;
using IBS.Common.PropertyClasses;
using Infragistics.Win.Misc;
using MindFusion.Diagramming;
using MindFusion.Diagramming.Lanes;
using MindFusion.Diagramming.Layout;
using MindFusion.Diagramming.WinForms;
namespace IBS.Controls
    public partial class SwimlaneControl : UserControl
        SwimlaneLayout _layout;
        private Grid _grid;
        private MindFusion.Diagramming.Lanes.Style _laneStyle;
        private MindFusion.Drawing.Pen _whiteSmokePen;
        private float _startZoomFactor;
        public SwimlaneControl()
            InitializeComponent();
            DiagramSetup();
        private void DiagramSetup()
            diagramView1.BackColor = Color.White;
            diagramView1.BackgroundImageLayout = ImageLayout.Center;
            diagramView1.Behavior = Behavior.Modify;
            diagramView1.ControlHandlesStyle = HandlesStyle.HatchHandles;
            diagramView1.ControlMouseAction = ControlMouseAction.SelectNode;
            diagramView1.DelKeyAction = DelKeyAction.DeleteSelectedItems;
            diagramView1.Diagram = diagram1;
            diagramView1.Dock = DockStyle.Fill;
            diagramView1.Location = new Point(0, 0);
            diagramView1.MiddleButtonActions = MouseButtonActions.None;
            diagramView1.ModificationStart = ModificationStart.SelectedOnly;
            diagramView1.RightButtonActions = MouseButtonActions.Cancel;
            diagramView1.Text = "";
            diagram1.ShadowsStyle = ShadowsStyle.None;
            diagram1.BackBrush = new MindFusion.Drawing.SolidBrush(Color.White);
            diagram1.Bounds = new RectangleF(0, 0, 1000, 1000);
            diagram1.LaneGrid.ColumnHeadersHeights = new float[] { 0 };
            diagramView1.ScrollTo(0, 0);
            _startZoomFactor = diagramView1.ZoomFactor;
            _grid = diagram1.LaneGrid;
            HeaderCollection columns = _grid.ColumnHeaders;
            _grid.MinHeaderSize = 20;
            _grid.HookHeaders = false;
            _grid.HeadersOnTop = true;
            _grid.AlignCells = false;
            _grid.AllowResizeHeaders = true;
            _whiteSmokePen = new MindFusion.Drawing.Pen(Color.WhiteSmoke, 0.01f);
            _laneStyle = new MindFusion.Diagramming.Lanes.Style
                BottomBorderPen = _whiteSmokePen,
                LeftBorderPen = new MindFusion.Drawing.Pen(Color.Transparent),
                RightBorderPen = _whiteSmokePen,
                TopBorderPen = _whiteSmokePen
            columns.Add(new Header("Client") { Width = 100f, Height = 120f, Style = _laneStyle });
            columns.Add(new Header("Server") { Width = 100f, Height = 120f, Style = _laneStyle });
            columns.Add(new Header("Database") { Width = 100f, Height = 120f, Style = _laneStyle });
            _grid.RowHeaders.Add(new Header("") { Height = 300f, Width = 0.1f, Style = _laneStyle });
            _grid[0, 0].Style = _laneStyle;
            _grid[1, 0].Style = _laneStyle;
            _grid[2, 0].Style = _laneStyle;
            _grid.AlignCells = true;
            diagram1.EnableLanes = true;
            diagram1.AlignToGrid = true;
            diagram1.LinkTextStyle = LinkTextStyle.OverLongestSegment;
            diagram1.RoundedLinks = true;
            diagram1.LinkEndsMovable = false;
        public void AddNodes(CallStackProperty callStackProperty, bool clearAllRecentNodes)
            if(CheckIfCallStackAllreadyExistsOnDiagram(callStackProperty))return;
            if (clearAllRecentNodes)
                DeleteAllExistingNodes();
            var activityID = callStackProperty.ActivityID;
            var correlationID = callStackProperty.CorrelationID;
            ControlNode titleNode = null, clientStart = null, serverStart = null, databaseStart = null, serverEnd = null, clientEnd = null;
            titleNode =
                CreateNode(
                    new UltraLabel
                        Text = string.Format("Activity ID:{1}{0}", activityID, Environment.NewLine),
                        AutoSize = true,
                        Font = new Font("Segoe UI", 8, FontStyle.Bold)
                    }, 0);
            if (callStackProperty.hasClientOutElement)
                clientStart =
                    CreateNode(
                        new NodeCtrl("Client", "start request", ETyp.ServiceBeforeSendRequest, activityID, correlationID),
                        0);
            if (callStackProperty.hasServerOutElement)
                serverStart = CreateNode(new NodeCtrl("Server", "start DB interaction", ETyp.ServiceAfterReceiveRequest,
                    activityID, correlationID), 1,-20);
            if (callStackProperty.hasDatabaseElement)
                databaseStart =
                    CreateNode(
                        new NodeCtrl("Database", string.Format("Duration: {0}ms", callStackProperty.DatabaseQueryTime),
                            ETyp.SQLLoad,
                            activityID, correlationID), 2);
            if (callStackProperty.hasServerInElement)
                serverEnd = CreateNode(new NodeCtrl("Server", "send result", ETyp.ServiceBeforeSendReply,
                    activityID, correlationID),1);
            if (callStackProperty.hasClientInElement)
                clientEnd =
                    CreateNode(
                        new NodeCtrl("Client", "received result", ETyp.ServiceAfterReceiveReply, activityID,
                            correlationID), 0,-20);
            if (clientStart != null && serverStart != null)
                ApplyDefaultStyle(diagram1.Factory.CreateDiagramLink(clientStart, serverStart), string.Format("{0}ms", callStackProperty.TimeFromClientToServer));
            if (serverStart != null && databaseStart != null)
                ApplyDefaultStyle(diagram1.Factory.CreateDiagramLink(serverStart, databaseStart), string.Format("{0}ms", callStackProperty.TimeFromServerToDatabase));
            if (databaseStart != null && serverEnd != null)
                ApplyDefaultStyle(diagram1.Factory.CreateDiagramLink(databaseStart, serverEnd), string.Format("{0}ms", callStackProperty.TimeFromDatabaseToServer));
            if (serverEnd != null && clientEnd != null)
                ApplyDefaultStyle(diagram1.Factory.CreateDiagramLink(serverEnd, clientEnd), string.Format("{0}ms", callStackProperty.TimeFromServerToClient));
            Rearrange();
            diagram1.RouteAllLinks();
            ResizeToFitItems();
            diagramView1.Diagram.ResizeToFitItems(1.0f);
        private void DeleteAllExistingNodes()
            diagram1.ClearAll();
            //var nodes =
            //    diagram1.Nodes.Select(node => node as ControlNode)
            //        .TakeWhile(controlNode => controlNode != null)
            //        .ToList();
            //foreach (var controlNode in nodes)
            //    diagram1.Nodes.Remove(controlNode);
            //nodes.Clear();
        private bool CheckIfCallStackAllreadyExistsOnDiagram(CallStackProperty callStackProperty)
            return
                    .Select(controlNode => controlNode.Control as NodeCtrl)
                    .Any(
                        detailControl =>
                            detailControl != null &&
                            (detailControl.ActivityID == callStackProperty.ActivityID &&
                             detailControl.CorrelationID == callStackProperty.CorrelationID));
        private ControlNode CreateNode(Control control, object laneLine, float movePosition = 0)
            var location = new PointF(0,0);
            var size = new SizeF(52f, 16f);
            var node = new ControlNode(diagram1)
                Control = control,
                Bounds = new RectangleF(location.X, location.Y, size.Width, size.Height),
                ControlMouseAction = ControlMouseAction.IgnoreControl,
                Brush = new MindFusion.Drawing.SolidBrush(Color.Black),
                ShadowBrush = new MindFusion.Drawing.SolidBrush(Color.WhiteSmoke),
                ForceControlRedraw = true
            diagram1.Nodes.Add(node);
            node.LayoutTraits.Add(MindFusion.Layout.SwimlaneLayoutTraits.Lane, laneLine);
            node.Move(0, movePosition);
            node.Locked = true;
            return node;
        private void ApplyDefaultStyle(DiagramLink link, string duration)
            link.RetainForm = true;
            link.DrawCrossings = true;
            link.Pen = new MindFusion.Drawing.Pen(Color.Black, 0.2f)
                DashStyle = System.Drawing.Drawing2D.DashStyle.Solid
            link.HeadPen = new MindFusion.Drawing.Pen(Color.Black, 0.2f);
            link.HeadShapeSize = 2;
            link.Brush = new MindFusion.Drawing.SolidBrush(Color.Black);
            link.Font = new Font("Segoe UI", 12, FontStyle.Bold);
            link.TextBrush = new MindFusion.Drawing.SolidBrush(Color.FromArgb(255, 222, 141, 0));
            link.TextPadding = new Thickness(15f, 0, -15f, 0);
            link.ShadowBrush = new MindFusion.Drawing.SolidBrush(Color.WhiteSmoke);
            link.TextAlignment = StringAlignment.Near;
            link.ZBottom(false);
            link.ZTop(true);
            link.Text = duration;
            link.Locked = true;
        public void ZoomIn()
            diagramView1.ZoomIn();
        public void ZoomOut()
            if(_startZoomFactor < diagramView1.ZoomFactor){diagramView1.ZoomOut();}
        private void ResizeToFitItems()
            var content = diagramView1.Diagram.GetContentBounds(false, true);
            content.Location = new PointF(0, 20);
            diagramView1.Diagram.Bounds = content;
        private void Rearrange()
            _layout = new SwimlaneLayout
                Anchoring = Anchoring.Ignore,
                CompactNodes = false,
                Direction = Direction.Straight,
                CollapseEmptyLanes = false,
                KeepGroupLayout = false,
                KeepLaneSizes = true,
                LaneDistance = 20,
                NodeDistance = 0,
                Orientation = MindFusion.Diagramming.Layout.Orientation.Vertical,
                Margins = new SizeF(
                    (int) diagram1.LaneGrid.GetRowHeaderBounds().Width + diagram1.Bounds.X,
                    (int) diagram1.LaneGrid.GetColumnHeaderBounds().Height + diagram1.Bounds.Y)
            _layout.Arrange(diagram1);
Re: strange behaviour in swimlane
Reply #1 - Dec 2nd, 2014 at 2:34pm
Apparently SwimlaneLayout.Arrange resizes the grid to match largest used lane index in nodes, so after second arrangement the database column disappears, and is added again with default style the third time.
I suppose you could refactor the code to add columns in CreateNode when you detect there's no lane for specified laneLine index, or otherwise add a temporary node to last column to make SwimlaneLayout keep it.
Michael
Reply #2 - Dec 3rd, 2014 at 3:12pm
Stoyo wrote on Dec 2nd, 2014 at 2:34pm:
This is solved my problem, thank you very match.
