Normal Topic how to reach the style like MS-Visio with diagram? (Read 2203 times)
heyx
Dec 22nd, 2014 at 8:04am
hi,
I want to use shapenod in diagram to reach the MS-Visio's Style.I attach the goal (and my project) I want to get? could you please give me some hepl?
Project.rar (Attachment deleted)
Re: how to reach the style like MS-Visio with diagram?
Reply #1 - Dec 22nd, 2014 at 10:19am
For selection appearance and moving from any point inside node, set HandlesStyle = Custom and handle the Draw/HitTest events like this:
void diagram_DrawAdjustmentHandles(object sender, DrawItemEventArgs e)
	var node = (DiagramNode)e.Item;
	var bounds = node.Bounds;
	bounds.Location = new Point();
	var handlesStyles = new[] { HandlesStyle.DashFrame, HandlesStyle.SquareHandles };
	foreach (var style in handlesStyles)
		InternalUtils.DrawAdjustmentHandles(
			e.Graphics,
			diagram.ActiveItemHandlesStyle,
			diagram.DisabledHandlesStyle,
			bounds,
			node.RotationAngle,
			node.EnabledHandles & ~AdjustmentHandles.Move,
			false,
			style,
			diagram.AdjustmentHandlesSize,
			node);
private void diagram_HitTestAdjustmentHandles(object sender, HitTestEventArgs e)
	var node = e.Item as DiagramNode;
	var size = new Size(
		diagram.AdjustmentHandlesSize);
	Rect r = e.Item.GetBounds();
	if (node != null)
		var location = node.Bounds.Location;
		var diagOffset = new Vector(location.X, location.Y);
		double rotationAngle = node.RotationAngle;
		Point localPoint = RotatePointAt(e.MousePosition, node.GetCenter(), -rotationAngle);
		if (r.Contains(localPoint))
			e.HitResult = 8;
		localPoint = localPoint - diagOffset;
		var TopLeft = new Point(0, 0);
		var TopLeftRect = new Rect(TopLeft, size);
		if (TopLeftRect.Contains(localPoint))
			e.HitResult = 0;
		var TopMiddle = new Point(node.Bounds.Width / 2 - size.Width / 2, 0);
		var TopMiddleRect = new Rect(TopMiddle, size);
		if (TopMiddleRect.Contains(localPoint))
			e.HitResult = 4;
		var TopRight = new Point(node.Bounds.Width - size.Width, 0);
		var TopRightRect = new Rect(TopRight, size);
		if (TopRightRect.Contains(localPoint))
			e.HitResult = 1;
		var MiddleLeft = new Point(0, node.Bounds.Height / 2 - size.Height / 2);
		var MiddleLeftRect = new Rect(MiddleLeft, size);
		if (MiddleLeftRect.Contains(localPoint))
			e.HitResult = 7;
		var MiddleRight = new Point(node.Bounds.Width - size.Width, node.Bounds.Height / 2 - size.Height / 2);
		var MiddleRightRect = new Rect(MiddleRight, size);
		if (MiddleRightRect.Contains(localPoint))
			e.HitResult = 5;
		var bottomLeft = new Point(0, node.Bounds.Height - size.Height);
		var bottomLeftRect = new Rect(bottomLeft, size);
		if (bottomLeftRect.Contains(localPoint))
			e.HitResult = 3;
		var bottomMiddle = new Point(node.Bounds.Width / 2 - size.Width / 2, node.Bounds.Height - size.Height);
		var bottomMiddleRect = new Rect(bottomMiddle, size);
		if (bottomMiddleRect.Contains(localPoint))
			e.HitResult = 6;
		var bottomRight = new Point(node.Bounds.Width - size.Width, node.Bounds.Height - size.Height);
		var bottomRightRect = new Rect(bottomRight, size);
		if (bottomRightRect.Contains(localPoint))
			e.HitResult = 2;
You could draw the red rectangles from either DrawAnchorPoint, DrawNode or DrawForeground event handlers. For first two options you will have to either set MarkStyle.Custom for anchor points or set node.CustomDraw = Additional.
heyx
Reply #2 - Dec 23rd, 2014 at 1:21am
hi Stoyan,
Thanks For your help,but I can't find any code of the method named 'RotatePointAt',
and I have tried the DrawAnchorPoint, DrawNode and DrawForeground event,
but those can't be raised when the mouse move on or in the node?
Could you please set it to me ?
« Last Edit: Dec 23rd, 2014 at 8:32am by heyx »
Reply #3 - Dec 23rd, 2014 at 1:32pm
Point RotatePointAt(Point point, Point pivot, double angle)
	Matrix rotation = new Matrix();
	rotation.RotateAt(angle, pivot.X, pivot.Y);
	Point res = rotation.Transform(point);
	return res;
Call node.Repaint or diagram.InvalidateForeground when you need to draw new highlight state.
