Normal Topic how to draw a single line like Ms-Visio? (Read 3022 times)
heyx
Dec 31st, 2014 at 2:03am
how to draw a single line like Ms-Visio in Diagram?
Re: how to draw a single line like Ms-Visio?
Reply #1 - Dec 31st, 2014 at 2:12pm
Set Behavior = DrawLinks and AllowUnconnectedLinks = true.
heyx
Reply #2 - Jan 4th, 2015 at 9:23am
hi Stoyan,
    I have tried as you told,but I find the start point of the lines which I crate is always the same. could you please tell me how to solve this?
   thanks very much!
Reply #3 - Jan 5th, 2015 at 9:16am
This looks like a bug we fixed a few releases ago, try moving to latest version 3.2. If you are already using latest one, please post your diagram initialization code.
heyx
Reply #4 - Jan 6th, 2015 at 5:15am
hi Stoyan,
   I have updated my project to version 3.2. but it still occur.I attach my project so you can check it .maybe it is my mistake.
Reply #5 - Jan 6th, 2015 at 2:51pm
Ok, the combination of RerouteLinks.WhileCreating and Anchoring.Keep flags in RoutingOptions does not work when you start drawing unconnected links. You could disable either of them when drawing such links, or handle InitializeLink like this as work-around:
void diagram_InitializeLink(object sender, LinkEventArgs e)
	e.Link.StartPoint = diagram.Interaction.CurrentPoint;
	e.Link.OriginConnection.SaveEndRelative();
