Normal Topic Anchor expansion (Read 2380 times)
j poz
Anchor expansion
Jan 21st, 2015 at 6:24pm
We want to implement a feature so that when a user hovers their mouse over an anchor, the anchor is grows in size to indicate we are over it. Do you have any suggestions for how to implement this functionality?
Re: Anchor expansion
Reply #1 - Jan 22nd, 2015 at 12:00pm
You could implement it by setting MarkStyle.Custom and handling DrawAnchorPoint event:
new AnchorPattern(new[]
	{ new AnchorPoint(50, 100, true, true, MarkStyle.Custom)},
	"test");
diagram.DrawAnchorPoint += OnDrawAnchorPoint;
private void OnDrawAnchorPoint(object sender, DrawAnchorPointEventArgs e)
	var mouseViewPosition = diagramView.PointToClient(MousePosition);
	var mousePosition = diagramView.ClientToDoc(mouseViewPosition);
	var rect = new RectangleF(e.Location, new SizeF(0, 0));
	if (Utilities.Distance(mousePosition, e.Location) < 3)
		rect.Inflate(3, 3);
	else
		rect.Inflate(1.5f, 1.5f);
	e.Graphics.DrawRectangle(Pens.Red, rect);
private void diagramView_MouseMove(object sender, MouseEventArgs e)
	var mousePosition = diagramView.ClientToDoc(e.Location);
	var node = diagram.GetNodeAt(mousePosition, 5);
	if (node != null && node.AnchorPattern != null)
		var r = node.GetRepaintRect(false);
		r.Inflate(3, 3);
		diagram.Invalidate(r);
Alternatively you could draw a filled shape from DrawForeground handler to cover the standard anchor point.
j poz
Reply #2 - Feb 2nd, 2015 at 6:19pm
Thank you. We were able to make this work. However, we want to make the expanded anchor appear over the diagramlink, but the diagram link seems to be drawn after DrawAnchorPoint so it gets drawn over our expanded anchor.
Is there a way to make this work the way we want it?
Reply #3 - Feb 3rd, 2015 at 11:38am
You could draw it from DrawLink handler instead:
		rect.Inflate(3, 3);
		highlightAnchorPoint = rect;
	else
RectangleF? highlightAnchorPoint;
private void diagram_InitializeLink(object sender, LinkEventArgs e)
	e.Link.CustomDraw = CustomDraw.Additional;
private void diagram_DrawLink(object sender, DrawLinkEventArgs e)
	if (highlightAnchorPoint != null && !e.Shadow)
		e.Graphics.DrawRectangle(Pens.Red, highlightAnchorPoint.Value);
		r.Inflate(3, 3);
	else if (highlightAnchorPoint != null)
		diagram.Invalidate();
		highlightAnchorPoint = null;
