Hot Topic (More than 10 Replies) How to label links to achieve my aims (Read 7901 times)
AR
Jan 23rd, 2015 at 11:20am
We are planning to use JDiagram to add the ability to draw simple diagrams to our product. These diagrams will have a small number of nodes (probably between 2 and 5) joined by one or two links. These links will all be labelled.
What we need the labels to do (ideally) is:
1. be movable by the user
2. be editable by the user
3. move with the link if it is moved (by 'bending' the link or moving one or both of the nodes it is linking)
4. have 'snap to my link' functionality so if the user moves it and forgets which link it associates with they can do something on the label (or the diagram) which causes it to 'snap' back to a default position relative to the link it is the label for.
Using the setText() or addLink() methods on the link adds labels that follow the link, but the text can 'cross' over the link and be difficult to read, and these can not be moved in relation to the link by the user.
Following a suggestion from a forum, I tried adding a 'ShapeNode' attached to the link. This allows moving of the label, but the label does not move when the link does and can be placed by any link not just the one it is 'attached' to.
Also I'm not sure how to find the instance of ShapeNode attached to a particular link so that a user can edit it.
The code I've used is:
Code (Java)
public void onLinkDoubleClicked( LinkEvent event )
		DiagramLink link = event.getLink();
		// Edit the label
		//link.setText( JOptionPane.showInputDialog( this, "Edit the label", link.getText()) ); // one label
		//LinkLabel theLabel = link.addLabel( JOptionPane.showInputDialog( this, "Edit the label", link.getText()) ); // many labels but overwrite each other!
		PointList pointsOnLink = link.getControlPoints();
		Float[] points = pointsOnLink.getArray();
		Rectangle2D rectangle2D = link.getEditRect(points[points.length/2]);
		ShapeNode label = diagram.getFactory().createShapeNode(rectangle2D);
		label.attachTo(link, AttachToLink.Point, points.length);
		label.setTransparent(true);
		label.setText(JOptionPane.showInputDialog( this, "Edit the label", ""));
		label.setIgnoreLayout(true);
		label.setAllowIncomingLinks( false );
		label.setAllowOutgoingLinks( false );
Have you any suggestions how I can achieve my aims regarding labels on links?
Re: How to label links to achieve my aims
Reply #1 - Jan 23rd, 2015 at 11:48am
If you use a LinkLabel for this, you could set its Brush property to add background color and make the text legible even if over the link graphics, and/or set its AutoArrange property to avoid the label overlapping with its link and nearby nodes.
Labels cannot be moved interactively at this time. You could probably use a temporary ShapeNode to implement label-editing mode that lets users specify new label position by moving the node.
Whether the node moves will depend on which link element it is attached to. E.g. if you attach to first control point, the node will move only when users move that point. Try different attach modes supported by the AttachToLink enum:
http://www.mindfusion.eu/onlinehelp/flowchartnet/T_MindFusion_Diagramming_Attach...
You could implement auto-arrange functionality for such attached nodes as shown here:
http://mindfusion.eu/Forum/YaBB.pl?num=1334837045/2#2
You can find nodes attached to a link by calling link.getSubordinateGroup().getAttachedNodes(); To get the node's master link call node.getMasterGroup().getMainItem();
AR
Reply #2 - Jan 23rd, 2015 at 3:21pm
Thanks that looks very help full - I will try your suggestions in my 'demo' application to see which looks best.
AR
Reply #3 - Jan 26th, 2015 at 5:59pm
Have been looking into this further, and the Java API doesn't have 'FixedDistance' or 'RelativeDistance' for the AttachToLink enum so I tried some of the others.
However, after I've called attachToLink() on the node (see code in original post), the link.getSubordinateGroup().getAttachedNodes() returns an empty instance of DiagramNodesList (and if I look at the label node itself it's MasterGroup is null) - are you sure this functionality has been implemented in the Java version?
Reply #4 - Jan 26th, 2015 at 7:34pm
If you meant attaching label to last point, pass points.length - 1 to index parameter instead of points.length:
label.attachTo(link, AttachToLink.Point, points.length - 1);
AR
Reply #5 - Jan 27th, 2015 at 11:00am
Unfortunately using other values such as points.length -1 or even just 1 make no difference - the subordinateGroup.attachedNodes remains empty on the link, and the masterGroup on the node being used as a label is still null.
Before I make the attachTo() call on the ShapeNode for the link, the subordinateGroup on the link is null, so something is happening to create the 'Group' item, but it is not being populated, and nothing is added to the label itself.
Attached is a minimal application (based on your IconNodes example) to reproduce this problem.
Reply #6 - Jan 27th, 2015 at 12:22pm
You are now using the AttachToLink.Segment attachment type; note that there are even fewer segments than control points especially for Bezier links, so the 4 control points you are seeing correspond to just one segment, and only 0 is accepted as a valid index. So replacing
label.attachTo( link, AttachToLink.Segment,points.length -1 );
// with
label.attachTo( link, AttachToLink.Segment, 0);
works for me and next double-clicks show the edit dialog.
AR
Reply #7 - Jan 27th, 2015 at 2:32pm
Thanks, that works beautifully and when the link is moved the label moves with it now - just what I wanted Smiley
AR
Reply #8 - Feb 26th, 2015 at 5:28pm
Just one more query to do with this - is there any way to prevent the user selecting and deleting the 'shapenode' being used as a label?
I do want them to be able to move it relative to the link, but I only want it deleted if the link itself is deleted.
Is this possible?
(I already have working code which deletes the label node when the link is deleted.)
Reply #9 - Feb 27th, 2015 at 8:57am
You can prevent this by handling the nodeDeleting validation event:
diagram.addDiagramListener(new DiagramAdapter() {
	@Override
	public void nodeDeleting(NodeValidationEvent e)
		Group group = e.getNode().getMasterGroup();
		if (group != null && group.getMainItem() instanceof DiagramLink)
			e.setCancel(true);
AR
Reply #10 - Mar 3rd, 2015 at 11:21am
Thanks that works exactly as I needed it to Smiley
