Normal Topic saveToXml( Document ) not working (Read 2683 times)
AR
Feb 9th, 2015 at 4:19pm
I want to save the diagram to XML then store it in a database. So I'm trying to save it to an in-memory XML document, which I can then store to the database. However it does not seem to work.
I have tried the following:
DocumentBuilder builder = factory.newDocumentBuilder();
            Document doc = builder.newDocument();
            Diagram.registerItemClass(MyClass.class, "MyClass", 1);
            diagram.saveToXml(doc);
            diagram.saveToXml("c:\\temp\\diagramFile.saved"); //added for debugging
But the value in 'doc' does not change at all (remains a null document).
However the file appears to be correctly written - it contains a large quantity of XML.
Am I calling the version that takes the 'doc' incorrectly?
Re: saveToXml( Document ) not working
Reply #1 - Feb 10th, 2015 at 9:05am
What do you mean by doc remaining a null document, does the doc variable itself have a null value?
AR
Reply #2 - Feb 10th, 2015 at 2:27pm
Sorry my mistake Embarrassed - wasn't looking at the contents of 'doc' correctly (or saving to db correctly) - it does seem to be okay actually.
