Normal Topic Text that goes over the shape boundaries (Read 6133 times)
Patrick Guerin
Mar 3rd, 2015 at 8:09pm
Could it be possible to have shapes which have text so long that it goes over the shape boundaries ?
Second question for text, is there a way to wrap the text inside a shape at "spaces" instead of cutting words in half.
Re: Text that goes over the shape boundaries
Reply #1 - Mar 4th, 2015 at 8:41am
This looks as in the 'want' image:
Shape decision = Shape.fromId("Decision");
decision.setTextArea(Shape.fromId("Rectangle").getOutline());
shapeNode.setShape(decision);
shapeNode.setText("Could it be possible to have shapes which have text so long that it goes over the shape boundaries ?");
shapeNode.setTextFormat(new TextFormat(Align.Center, Align.Center));
shapeNode.getTextFormat().setWrapAtCharacter(false);
Patrick Guerin
Reply #2 - Mar 4th, 2015 at 2:37pm
Yes, it's work perfectly.   Smiley
One more question, is there a way to change the textArea size ?  (We want to know if it's possible to get a greater rectangle).
And in case of very very long text, is there a kind of function like "ShapeNode.resizeTextToFitShape()" ?
Actually, the only function available is ShapeNode.resizeToFitText(fit).  But we don't want to resize the shape of the node to the matched text lenght, but the size of the text inside the TextArea (Fixed size of the TextArea.
Thanks for your great help !
Reply #3 - Mar 4th, 2015 at 5:04pm
Shape geometry coordinates are specified as percentage of node size, so this will make the text area twice larger that the node:
decision.setTextArea(new ElementTemplate[] {
	new LineTemplate(-50, -50, 150, -50),
	new LineTemplate(150, -50, 150, 150),
	new LineTemplate(150, 150, -50, 150),
	new LineTemplate(-50, 150, -50, -50)
Do you mean changing the font size so that text fits inside current shape?
Patrick Guerin
Reply #4 - Mar 4th, 2015 at 5:12pm
Yes, exactly, but, we don't want to use try/error value until we get the right font size to fit the text into the TextArea location.  We want to get the "proportional" font size to be able to fit all text into the TextArea location.
Thanks for your help.
Reply #5 - Mar 5th, 2015 at 11:09am
I don't think there is linear proportionality between the font size and text layout size, mostly because of how line breaks would change positions, but possibly including other minor peculiarities of font rendering such as kerning.
You might try measuring with proportional font size only as a starting point, but then would still need to do a few tries to make sure text fits. E.g. try something like this:
// assuming rectangular shape
void fitText(ShapeNode node)
	Rectangle2D.Float nodeRect = node.getBounds();
	double nodeArea = nodeRect.width * nodeRect.height;
	Font font = node.getEffectiveFont();
	float paddingWidth = 2, paddingHeight = 2;
	Thickness padding = node.getTextPadding();
	if (padding != null)
		paddingWidth = padding.getLeft() + padding.getRight();
		paddingHeight = padding.getTop() + padding.getBottom();
	Dimension2D textSize = TextRenderer.measureText(
		node.getText(), nodeRect.width - paddingWidth, font);
	double textArea = textSize.getWidth() * (textSize.getHeight() + paddingHeight);
	while (textArea > nodeArea)
		// due to changing line break positions, text area might not be strictly decreasing function?
		// make sure font size always decreases to avoid infinite loop
		double newSize = font.getSize2D() / Math.sqrt(textArea / nodeArea);
		newSize = Math.min(newSize, font.getSize2D() - 1);
		font = font.deriveFont((float)newSize);
		node.setFont(font);
