Normal Topic Styled text in a TextComponent? (Read 4779 times)
AR
Apr 7th, 2015 at 4:04pm
I would like to style the text within a TextComponent within a custom CompositeNode.
I tried calling diagram.drawStyledText() within a 'drawLocal() on my custom CompositeNode but this gives a slightly displaced shadow text - so I can see both the styled and plain text at the same time (See attached image for example of what I'm getting and what I need)
Is there a better way of doing this?
Re: Styled text in a TextComponent?
Reply #1 - Apr 7th, 2015 at 7:33pm
If you call super.drawLocal it will also render standard TextComponent's graphics along with text, and drawStyledText will draw over the already rendered unformatted text. You could avoid that by setting component's TextColor to transparent, but then you wouldn't have much use for the hosted components.
In order to change font attributes for all text of a TextComponent, you could assign them through its Font property. E.g. you could specify it in XML definition in format that can be parsed by Java's Font.decode method:
<Text Name="Text" Font="Arial-italic-4" TextAlignment="Near" />"...
If you prefer more-varied formatting via HTML tags, better override TextComponent.draw method in custom class:
package com.myorg;
import java.awt.Graphics2D;
import com.mindfusion.diagramming.*;
import com.mindfusion.diagramming.components.*;
public class StyledTextComponent
	extends TextComponent
	@Override
	public void draw(Graphics2D g2d, RenderOptions options)
		Brush textBrush = new SolidBrush(getTextColor());
		textBrush.applyTo(g2d, getBounds());
		if (options.getTargetView() instanceof DiagramView)
			DiagramView view = (DiagramView) options.getTargetView();
			view.getDiagram().drawStyledText(
				g2d, getText(), getFont(), getBounds(), getTextFormat(), textBrush);
and then load the custom component from XML template by specifying its full name:
<com.myorg.StyledTextComponent ... />
AR
Reply #2 - Apr 8th, 2015 at 12:49pm
Thanks - the over-ride to get HTML styled text is working very well - just what I needed. Smiley
AR
Reply #3 - Apr 8th, 2015 at 3:27pm
Do I need to override something else in the 'StyledTextComponent' so that when I call diagram.createImage() I get the text output?
The diagram on screen looks fine, but when I create an image I loose the entire contents of the 'StyledTextComponent'
Reply #4 - Apr 8th, 2015 at 6:06pm
Apparently there isn't DiagramView associated with RenderOptions when exporting images. Try this version of draw method instead:
@Override
	CompositeNode node = (CompositeNode)getParentHost();
	node.getParent().drawStyledText(
AR
Reply #5 - Apr 9th, 2015 at 8:59am
Smiley That works.
We add the image to a Word report and it looks fine now.
Thank you for your help.
