Normal Topic Bind calendar items to custom form (Read 4459 times)
Christiaan
Apr 28th, 2015 at 6:49pm
HI
What is the easiest way to bind non common fields to a custom appointment form.
I have added 2 fields to my custom appointment form, but can't seem to get them to bind when my user double click on the item.
I get all the fields linked to item class and appointment class. but would like to add custom1 and custom2 field.
here is my code for my form when user double click a item:
Appform.Subject = e.Item.HeaderText
            Appform.Description = e.Item.DescriptionText
            Appform.Date1 = e.Item.StartTime
            Appform.Date1T = e.Item.StartTime
            Appform.Date2 = e.Item.EndTime
            Appform.Date2T = e.Item.EndTime
            Appform.Chkalldaye = e.Item.AllDayEvent
Appform.ShowDialog()
I would like to add : appform.custom1 = e.item.department
                            appform.custom2 = e.item.shift
i am new with this, so any help would be appreciated
Re: Bind calendar items to custom form
Reply #1 - Apr 29th, 2015 at 7:40am
There should be no difference between assigning custom and regular item properties to the properties of your form. What exactly is the problem you are facing?
Christiaan
Reply #2 - Apr 29th, 2015 at 11:14am
Hi Meppy
Sorry for sounding dumb on this, but i get this error
Error      28      'Department' is not a member of 'MindFusion.Scheduling.Item'.
Reply #3 - Apr 29th, 2015 at 11:39am
You need to cast the item to your custom type. For example, if the custom item type is MyItem, you can do the following:
Dim item As MyItem = CType(e.Item, MyItem)
Then you can assign to the form properties:
appform.custom1 = item.department
appform.custom2 = item.shift
Christiaan
Reply #4 - Apr 30th, 2015 at 7:35am
Thank you Meppy!! Now I understand what I need to do
