Normal Topic Detect multiselect types (Read 2248 times)
JHanson
May 29th, 2015 at 8:07pm
I need to distinguish between when a user selects multiple nodes by dragging a rectangle around them with the mouse and when they select multiple nodes individually by using the CTRL key and clicking.
Re: Detect multiselect types
Reply #1 - Jun 1st, 2015 at 7:53am
Inside NodeSelecting validation event handler you could detect that by comparing e.SelectionRectangle with RectangleF.Empty. An empty rectangle means CTRL-click selection.
Alternatively, for both Selecting and Selected events you could inspect the Diagram.Interaction object:
private void diagram_NodeSelected(object sender, NodeEventArgs e)
	if (diagram.Interaction != null &&
		diagram.Interaction.CurrentItem is Selection)
		Debug.WriteLine("lasso selection");
	else
		Debug.WriteLine("click selection");
JHanson
Reply #2 - Jun 1st, 2015 at 2:18pm
Excellent, thank you!
