Normal Topic Diagramming for JavaScript, V2.4 (Read 3539 times)
Jun 10th, 2015 at 9:13am
We have released version 2.4 of MindFusion.Diagramming for JavaScript. It contains the following new features:
Appearance improvements
  • Set the Shape property of tables and containers to RoundedRectangle to render them with rounded corners.
  • Hide the frames of table cells by setting the CellFrameStyle property to None.
  • Set the EnableStyledText property of TableNode class to render styled text in tables.
New events
  • The control raises cellTextEdited event when users edit the text of table cells.
  • The createEditControl event lets you create custom DOM element or fragment to use as in-place text editor.
  • NodeListView raises nodeSelected event when the user selects a node.
  • jQuery mode is now the default and all sample projects have been updated to use jQuery. To continue using the Microsoft Ajax library, set MindFusionImpl = "MsAjax" before loading Diagramming.js
  • the loadFromXml method of Diagram class lets you load XML files created by MindFusion diagram controls for other platforms.
  • fixed setZoomFactorPivot bug in virtual scroll mode.
