Normal Topic FlowChartX V4.9.1 released! (Read 2311 times)
Jul 8th, 2015 at 9:00am
We have released version 4.9.1 of FlowChartX. It contains the following new features and fixes:
Highlight table rows
Set the HighlightedRow property of a Table to the index of a row that should be drawn highlighted. Highlighted rows' background is painted in RowHighlightColor. If you enable the AutoHighlightRows property, a row will be highlighted automatically when clicked.
~ VisioImporter, VisioExporter and SvgExporter has been merged into the main flowchartx.dll library file, and can now be used with its 64-bit version.
~ Set the BackColor property of ArrowLabel to fill the background of link labels.
~ Link segments now connect to the base of arrowhead shapes instead of going all the way through them, letting you use transparent and semi-transparent fill color for arrowheads without seeing segment ends inside.
~ Fixed crash in 64-bit SaveToBitmap function.
https://www.mindfusion.eu/FCXdemoPro.zip
« Last Edit: Jul 13th, 2015 at 11:48am by Forum Admin »
