Normal Topic How to replace image of row of tablenode (Read 3523 times)
CanadaProgrammer
Jul 11th, 2015 at 11:05am
I can insert rows to a table node, if a row includes child rows then there is image at left of the row to indicate this row expand or collapse. My question is how to show my image to replace to default image?
CanadaProgrammer
Re: How to replace image of row of tablenode
Reply #1 - Jul 11th, 2015 at 11:09am
BTW:
my code like below:
this[0, currRow].Brush = new MindFusion.Drawing.SolidBrush(Color.FromArgb(0, 0, 0));
this[0, currRow].Font = MDGdi.NewRowFont;
this[0, currRow].Image = EmImages.SimpleEntity;
Only font can work, that is what I want. But Image and Brush does not effect the appearance of TableNode shape
Reply #2 - Jul 13th, 2015 at 9:11am
You cannot change the collapse icon appearance at this time. Brush and Image properties of cells work fine in my test, check if you aren't resetting them to null values later.
CanadaProgrammer
Reply #3 - Sep 29th, 2015 at 8:20am
hi,
Thanks for your reply. Yes, actually I do want to change collapse icon. You say "You cannot change the collapse icon appearance at this time". I can not understand this sentence very well.
If you mean
1. I can not change the icon always
    This case, I will try to draw a icon by myself and that is what I do right now.
Or
2 I can not change the icon at that time.
   This case, It sounds there is an another time or other time that I can change the icon so what is the another time or other time?
Thanks a lot
Reply #4 - Sep 29th, 2015 at 9:20am
By "at this time" I mean that at the time of writing this there are no options provided in public API to replace the +/- icon. However one might appear in newer versions, so future readers of this forum post should not jump to conclusions Smiley
