Normal Topic Tool tip not working in SvgImage Mode Diagramming (Read 2493 times)
Pazhanivel
Sep 4th, 2015 at 6:38am
    I am new to mindfusion Diagramming.I have created Decision Diagram using SvgImage Mode, in that While mouse over on the Shapenodes tooltip not working.
Re: Tool tip not working in SvgImage Mode Diagramming
Reply #1 - Sep 4th, 2015 at 8:27am
SvgImage mode is not officially supported, you should use only the modes listed at http://www.mindfusion.eu/onlinehelp/netdiagram/index.htm?NetDiagram_front_ends.h...
If tooltips are all you miss, we could probably implement them for next release, but other features such as user interaction, events and client-side API support aren't likely to appear.
Pazhanivel
Reply #2 - Sep 7th, 2015 at 11:37am
Thanks Stoyan  Smiley Smiley Smiley
